HEDS 968 Hoover dishwasher.
Home Forums Public Support Forums Help And Support Dishwasher Help Forum HEDS 968 Hoover dishwasher.
  • #98773
    lindajones
    Hello. Could someone by any chance ID this bit of my dishwasher that’s fallen out after being moved? Can’t for the life of me find out where it should be located ​​​​​​
    https://ibb.co/VNdt86m
    https://ibb.co/B4JpSrm
    #473756
    thats the oveflow detector. there should be a polystyrene float to go with it that activates the switch if water gets down there
    https://www.ebay.co.uk/itm/Currys-es…gAAOSwF9FfV5ie
    this may be the correct part complete with float as i am fairly certain hoover dishwashers are made by the same people
    look for yourself and decide
    lindajones
    Thanks Dave. I shall have to buy another, the poly float has gone missing. Do you have any idea where it should be located?Looking at the underside it’s not obvious..
    electrofix wrote:thats the oveflow detector. there should be a polystyrene float to go with it that activates the switch if water gets down there
    its bolted to the floor pan underneath the dishwasher
    what worries me is normally this part cant be damaged as there is a steel plate or plastic in some cases across the bottom of the dishwasher
    watch this
    https://www.youtube.com/watch?v=7b1-M_WKYJs
    you can see your part attached to the steel base
    lindajones
    Ah, I see now. I’m guessing the removal men haven’t been especially careful, I have no steel or plastic plate? I’ll have to check and see if they can be bought and the moving company can pay for it! I dread to think of what further damage they could have done. Never rains but…
    #473760
    the base is the sort of part that does not go so you may stuggle to get it
    all you can do is contact hoove to see if you can get one
    https://shop.hoover.co.uk/gb_en/spare-parts
    but if its been ripped off you may have problems securing it again
    suggest you look down the route of claiming on the movers insurance at least tell them as the longer you leave it the more likley they can blame you
    lindajones
    Was wondering if anyone knew why this machine is now either filling then emptying or trying to fill and emptying at the same time? Got the baseplate sorted but still not playing nice?
    #473762
    make sure outlet hose is at correct height and cant syphon out
    lindajones
    electrofix wrote:make sure outlet hose is at correct height and cant syphon out
    OK will try that.
