Height of cooker hoods above gas hobs
Home Forums General Trade Forum Height of cooker hoods above gas hobs
  • #90885
    DASLTD
    Just a general question,
    i know when installing a new gas hob you should generally allow a clearance of 700mm to the cooker hood if they don’t specify in the installation manual, however what is the rules if you are changing the cooker hood and leaving the gas hob in place, do the same rules apply ?
    Simon
    #446337
    Re: Height of cooker hoods above gas hobs
    If the hob and hood are from the same manufacturer then you can go by their distance normally between 600mm-800mm.
    If the appliances are from different manufacturers then they fall into the BSEU standard regs. electric 650mm 760mm for gas. If it has a large output wok burner they I would recommend 800m.
    Bryan
    #446338
    DASLTD
    Hi Bryan , is that the same if the old hob is staying in situ ?
