Height reduction for SMEG WDF16BAX1 Washer Dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Height reduction for SMEG WDF16BAX1 Washer Dryer
  • #52654
    sunny23
    Does anyone know if Smeg makes a height reduction kit for their stainless steel washer dryer WDF16BAX1 ? It was delivered yesterday but won’t fit. The delivery man suggested I have the feet removed but this makes me nervous especially as the floor is slate and therefore uneven. Thanks for your HELP!
    #312610
    don
    Re: Height reduction for SMEG WDF16BAX1 Washer Dryer
    Hi sunny23
    There is no mention of a height reduction kit for any of the Smeg machines in either the instruction manual or the sales blurb.
    You could try ringing them on one of the contact numbers listed.
    Failing that remove the lid and if it is okay to do so make up your own lid from perhaps an old lid from a scrap machine, local recycling centre may help you out if you ask nicely.
    HTH 🙂
    Don
    #312611
    sunny23
    Thanks Don. I’ll follow up on your leads and maybe I’ll get lucky! I guess I could even have a piece of stainless steel custom cut for the top. Do you know how can I find out how to remove the top of the washer? Thanks again!
    #312612
    don
    Lids are usually held by two screws at the rear or screws on either side, once removed lid usually slides towards towards the rear.
    Be safe power off :zap: first.
    Don
