Height reduction kits for bosch
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Height reduction kits for bosch
  • #51020
    morgmonster
    We have just moved into our first house. We have a 2nd hand Bosch WFO2467GB washing machine from my grandma, and have bought a Bosch SGS45C02GB dishwasher which is due to be delivered today.
    We thought we had measured the under-worktop space OK on a viewing visit, and knew it would be tight but thought “standard size” appliances would fit fine. However we didn’t realise until moving in that the tiling in the space is hideously uneven – some are 1cm different in height. Obviously this makes moving the machine a bit of a nightmare.
    We’ve taken the nuts off the feet, and think probably we can just squeeze it in with a lot of huffing and puffing. However I think we might need the nuts back on – since the feet are going to need to be at different heights due to the tiles – so it would be a lot easier if there was a height reduction kit for these two appliances.
    Does anyone know? Thanks very much for your help! 😀
    #306636
    don
    Re: Height reduction kits for bosch
    For the washing machine I cannot find any mention in the Bosch E-shop I did try several different versions as I didn`t have the full ENR number 😉 You could try ringing them on 0844 892 8921 to make sure.
    The dishwasher is a current machine and again there is no reduction lid listed either in the catalogue or in the shop. You could always knock one up yourself by modifying an old washing machine lid.
    If you do phone Bosch don`t forget to have the full ENR no. and the fd no. to hand.
    HTH 🙂
    Don
    #306637
    morgmonster
    Hi thanks I will look up those numbers and give them a call.
    Otherwise time to get my DIY hat on!
    Thanks a lot,
    Rachel
