hello Samsung J1253/J845
  • #36051
    robots
    Hello,
    have a Samsung J845 ( i am in Australia) which is identical to a J1253,
    could hear a noise during wash, so at end took filter cap off to reveal a 5 cent coin and paper clip, and another larger pin
    re-screwed fliter cap and ever since have had a reasonable leak from the filter cap (maybe a half to one litre), have taken filter out and rescrewd but again leaks
    does the filter cap “seal” need replacing or is something more serious,
    any help appreciated
    thankyou
    robots
    #249377
    Simon46
    Re: hello Samsung J1253/J845
    Is there lugs on the filter which slide in/line up on the pump body vortex chamber?
    S.
    #249378
    robots
    hello,
    yes, the filter cap has a white plastic attachment which slides into the chamber, there is 2 grooves in the chamber and I have been sliding it into these
    the white attachment which is attached to the filter cap also has a rubber seal on it
    thankyou
    robots
    #249379
    robots
    hello,
    during normal operation does the filter chamber fill with water?
    thankyou
    robots
    #249380
    It’s the lowest point of the machine……..
    Ensure that there are absolutely no deposits lying in the threads where the filter screws in. It will stop it going home and water will dribble out.
    robots
    hello,
    thanks penguin,
    I ordered a new filter cap but it didnt come with a new rubber seal so will get that also,
    regards
    robots
