help
  • #8573
    my diplomat dishwasher has stopped work again.on the screen it just says p0 and when i press the pr button nothings happens.also on the screen there is 3 sqiggly lines with a cross over them and next to it is 1/2
    when i shut the door it makes funny noices as if it is trying to empty
    please help as my hands are getting to soft
    #129410
    Re: help
    You wiil probably find that the machine has leaked into the undertray and operated the floatswitch. This turns on the drain pump and over-rides the computer. With the power off :plug: drain the undertray to reset the switch. However, you do need to find the source of the leak.
    Re: help
    can you tell me where the undertray is and how to drain
    #129412
    Hi Fazzer,
    If you’re unsure at that stage I would honestly recommend that you get an engineer in to look at the machine. You can try Repairs@ over on the navigation bar or the Directories to find a repairer. If you’ve no luck in either pop your postcode up and I’ll see what I can find for you.
    Re: help
    no luck with finding an engineer if you could give me a few pointers on how to drain i will give it a go,i got nothing to lose,if i cant fix i will have to pay out for new one ,so i might as well try
    #129414
    What’s the model number?
    But in essence there’s a baseplate (the names a giveaway ;)) that requires drained possibly. There are other reasons for this to occur but it’s a start.
    However, as P says that’s only the start.
    Re: help
    model no adp 8234 type 12043
    #129416
    Guys,
    Someone refresh my memory please is that the Whirlpool one? If so Dentedporche is the resident expert on them. 😉
    Re: help
    no its a diplomat dishwasher
    #129418
    Re: help
    Fazzer,
    Diplomat have never made a dishwasher in their lives – they are all bought in and badged. Between us we should be able to work out who made it, then we might get nearer to the answer.
    Re: help
    i got the make and model no off the sticker on the side of the door
    #129420
    Re: help
    Yup, no problem Fazzer – we now have enough info to work out what it REALLY is 😆 .
    Re: help
    Ok, it’s a SMEG-made dishwasher, which is a bit unfortunate. Normally, faults are indicated by codes being displayed on the screen. If you have a “random” screen, no programming and strange operations taking place, it is more than likely that the computer board has failed.
    At this point, you need to get pro help. The computer board will be an expensive component, so it will be in your own interest to have the diagnosis confirmed professionally.
    Check repairs@ukwhitegoods.com or Directories for a UKW repairer in your area.
    Dave_Conway
    Re: help
    I think fazzer has tried that route P to no avail if it’s the same email I got earlier.
    Pop your postcode up please, one of the guys should pick it up hopefully, if not, phone MFI Extracare on 08457 959722 as they will have an agent in your area.
