Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Help/advice oven door – BEKO SCG 7521 W gas cooker
- This topic has 8 replies, 2 voices, and was last updated 8 years, 10 months ago by
spudexter7.
May 30, 2017 at 6:37 pm #91347
spudexter7
ParticipantHello,
Was hoping to get some DIY advice on how to fix a small issue. I got this BEKO SCG 7521 W gas cooker (used) for free from a friend to replace my other BEKO gas cooker (DVG 593). The main oven door doesn’t close all the way at the top. A small crack is left (see images) where all the heat just poors out, a huge was of energy. I have removed the cover of the door and the hinges seem to be in good working order and secured to the door quite well so don’t know if there is something bent or what.
Question 1- Does anyone have any ideas on what the issue might be and how to fix it?
Question 2 – Any suggestions on cheap DIY tricks or hacks to keep the door closed all the way at the top during use? (ex. I thought of installing a latch on one side of the door perhaps)
Any help and suggestions would be super helpful and many thanks for your time in advance.
Cheers,
May 30, 2017 at 8:23 pm #447792electrofix
ModeratorRe: Help/advice oven door – BEKO SCG 7521 W gas cooker
its either the hinges or the hinge receivers. most likely the hinges ( but I cant guarantee )
https://shop.ukwhitegoods.co.uk/4109200 … door-hinge
May 30, 2017 at 9:58 pm #447793spudexter7
ParticipantRe: Help/advice oven door – BEKO SCG 7521 W gas cooker
Thanks for the quick reply and the link.
Do you think I could use the hinges in my BEKO DVG 593 top grill door?
Cheers,
May 31, 2017 at 7:40 am #447794electrofix
No the spring tension is lower so it wont hold the door weight
May 31, 2017 at 6:14 pm #447795spudexter7
Thanks again for the reply. I think I found what the culprit is and would kindly ask for confirmation.
The hinge works fine, and there doesn’t seem to be any untoward wear and tear on the receiver or the hinge itself. Upon close inspection I noticed that it is actually where the receive is fastened to the chasis/main body of the oven. I noticed there is a distinct bulge where the top end of the receiver screws in (see pics…difficult to see but you really notice it if you run your finger along the edge of the door opening).
This would fit with the theory that excess weight was put on the door while open so the receiver doesn’t sit exactly perpendicular to the door opening, hence the small gap at the top of the door when door is closed.
Question 1 – Is this correct?
Question 2 – Can I ‘hammer’ it back to flush by laying the oven on its back?
Question 3 – What would you do?
Many thanks once again,
Cheers,
May 31, 2017 at 6:32 pm #447796electrofix
take it apart. remove the strength plates then straiten the plate on its own. casing is only light steel so it you put something heavy and straight behind it you should be able to tap it back to shape. Just like a panel beater would do on a bent car
dave
May 31, 2017 at 6:45 pm #447797spudexter7
Cheers!
May 31, 2017 at 6:58 pm #447798electrofix
this is what the receivers look like
there are 2 of them and left and right are opposites so wont interchange
June 2, 2017 at 10:17 am #447799spudexter7
Got it sorted. I was going to disassemble but BEKO doesn’t make it easy. I figured I would have had to disassemble half the oven just to get to the receiver and couldn’t find a technical manual or instructions online for the life of me. In the end I decided to take the hinge off the door, remove the top screw of the receiver, and insert the hinge inverted into the receiver, and just yank on it a bit until the edge was flush and the receiver was in oriented correctly. Worked like a charm!
Thanks for the help!
