HELP Ariston oven – faulty door
Home Forums Public Support Forums Help And Support Cooker And Oven Forum HELP Ariston oven – faulty door
  • #9971
    I have a five year old Ariston oven and the model number on the paper work is:
    FV 37 GB
    FV 34D GB
    The glass panel on the centre of the door has come off and needs refixed however I don’t know how to remove the door. If anyone could offer some advice I would be more than thankful.
    John
    #137018
    Hi John,
    If that’s off the instruction manual then it’s probably of little use, search for the rating plate as that will have the correct model and serial number on it.
    Re: HELP Ariston oven – faulty door
    Three different models of FV34D dependant on colour. There are three different hinges used on this machine. A silver ‘normal’ hinge a sliver ‘roller’ hinge and a black ‘heavy duty’ hinge. Very different in construction and removal.
    Some manufacturers include instructions on door removal, via the hinges in their user manual, have you checked for this?
    #137020
    Check this link for various types of door removal:
    http://www.ukwhitegoods.co.uk/modules.p … pic&t=3771
    Dave_Conway
    Check the “sticky” at the top of this forum I did a few weeks ago “removing oven doors for cleanig”, it shows two small video clips (kindly provided by BSH for their customers) but it gives a fairly good indication of how to remove both of the more common types of oven door as many manufacturers use a similar type of arrangement.
    #137022
    :wave:
    #137023
    Dave_Conway
    :wave:
    Oops :martin:
    #137024
    pridmorej
    Thanks guys.
    Those videos saved me a shed load of time and, as frustration levels were on target to kick the oven out of the back door, a shed load of cash as well 🙂
    The inside and outside glass fell out and I needed to get the door off to replace it.
    Jeremy
