Help Bauknecht GSF7199 Error code F8
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Help Bauknecht GSF7199 Error code F8
  • #15952
    tm
    😥 Our loyal dishwasher has stopped working. Nothing responds and on the display it says F8
    Please advise
    #166881
    gegsy
    Re: Help Bauknecht GSF7199 Error code F8
    F8 is a problem concerning the water level.
    1/Check your filters arent blocked and that you arent using 3 or 4 in 1 tablets in conjunction with rinse aid as this will result in excess foaming.
    2/A faulty recirculation pump or blockage within is a possibility.
    3/Faulty water indicator also a factor.
    Check (1) and if ok then its engineer time see below.
