Help Bosch dishwasher Timer dial getting stuck
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Help Bosch dishwasher Timer dial getting stuck
  • #43848
    rowl3y
    I Cart really find the model number of the dishwasher but its a slimline
    but it has 3 programs on the the dial its a good few years old and working perfect
    but from the other day on the program 3 the full heated wash i get stuck in one place
    if i just click it on it will carry on on its own.
    What could be the people and is this a easy fix
    thanks
    #278815
    Re: Help Bosch dishwasher Timer dial getting stuck
    Does it heat?
    Model number is at the top of the casing surround on old machines or etched into the top edge of the door on newer ones. Crucial bit of info, really.
    rowl3y
    OK i will have a look..
    yeah it heat up no problem and washes but just get stuck in the wash when washing half way round
    #278817
    rowl3y
    ok the model number is
    SPS2462GB/19
    hope anyone can help
    #278818
    Check where the wiring loom hinges under the tub – remove door outer for access. Broken wires were a common probolem. Otherwise, if it hangs at exactly the same point every time, it may well be the timer.
    P/no 092127, around £85 – may be a slightly debatable repair on a machine of this age.
    Power off if you intend to repair this yourself.
