Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › HELP Bosch washing machine changing door seal
- This topic has 16 replies, 5 voices, and was last updated 12 years, 6 months ago by
j3lly.
September 23, 2013 at 9:21 am #77278
j3lly
ParticipantHi
I need to change the door seal on a Bosch washing machine
Model is Bosch Classixx 6 1200 express
Couple of questions
Where is the best place to get a replacement door seal
How hard a job is it
Is there a guide somewher describing this jobMany thanks
September 23, 2013 at 9:32 am #401620j3lly
ParticipantRe: HELP Bosch washing machine changing door seal
looking around for a replacemnt seal is it
BS18107 I needThanks
September 23, 2013 at 9:34 am #401621don
ModeratorRe: HELP Bosch washing machine changing door seal
Hi j3lly
You can purchse the door seal through our spares shop here , you will need the ENR and FD number which can be found on the inside of the door frame to get the correct one.
If you are competent DIYer not to bad a job, there are some videos on You Tube as well if you are not sure.
If you are not sure you can always use our find an engineer here who will carry out the job for you.
HTH 🙂
Don
September 23, 2013 at 10:35 am #401622j3lly
Serial as stated on invioce is
WAE24363GB1
Looking around I believe that I need door seal part number
BS18107
But cannot seem to find the part number in the lists of Bosch door seals
Am I missing somethingThanks
September 23, 2013 at 11:03 am #401623don
don wrote: you will need the ENR and FD number which can be found on the inside of the door frame to get the correct one.
Don
If your’e ENR is WAE24363GB/11 then the door seal is one of these two in our shop.
DonSeptember 23, 2013 at 11:16 am #401624j3lly
had a look on the plate inside of door the number is
E-Nr
WAE24363GB/05
FD 8901 603624Sorry for the confusion I got the original number from the invoice
September 23, 2013 at 11:23 am #401625don
Still the same part number as in my previous post :tup:
Don
September 23, 2013 at 7:00 pm #401626Grumps
j3lly wrote:Hi
I need to change the door seal on a Bosch washing machineI see you found your way from the Ultimate Handyman site. 😀
September 23, 2013 at 7:50 pm #401627don
Grumps wrote:
Thanks for your recommendation Grumps on the UH forum very kind of you 😀
DonSeptember 25, 2013 at 7:43 pm #401628j3lly
Thanks for the help guys wonderful service
October 4, 2013 at 3:17 pm #401629j3lly
Have changed door seal for a genuine Bosch replacement
Retaining ring for the door is a solid wire ring with a 80mm ish spring
The spring does not seem to seat correctly
Have refitted twice with the spring in a different orientation with the same result
Have run machine and have NO LEAKS so all good there
I am just being paranoid about the spring not seating correctly
Or is there a way of getting it to seat correctlyThanks
October 4, 2013 at 4:02 pm #401630Andy jones
Any chance you could post a pic. We could see if it looks ok
Sent from my iPad using Tapatalk HDOctober 4, 2013 at 4:14 pm #401631Martin
j3lly wrote:Iam just being paranoid about the spring not seating correctly
Or is there a way of getting it to seat correctlyThe spring is best located just below the door hinge area. Seating the spring neatly behind the rubber flange achieved with a little application of soapy water…..’tis all! 🙂
October 4, 2013 at 5:15 pm #401632j3lly
As martin states spring was originally just below door hinge have tried here and 2 other places with the same result
Here’s a photo as it sits now at 12-00
Thought this would be best place as less likly to leak
October 4, 2013 at 5:36 pm #401633Martin
That position is fine!
