HELP Bosch washing machine changing door seal
Home Forums Public Support Forums Help And Support Washing Machine Help Forum HELP Bosch washing machine changing door seal
Viewing 15 posts - 1 through 15 (of 17 total)
  • #77278
    j3lly
    I need to change the door seal on a Bosch washing machine
    Model is Bosch Classixx 6 1200 express
    Couple of questions
    Where is the best place to get a replacement door seal
    How hard a job is it
    Is there a guide somewher describing this job
    Many thanks
    #401620
    j3lly
    Re: HELP Bosch washing machine changing door seal
    looking around for a replacemnt seal is it
    BS18107 I need
    #401621
    don
    Hi j3lly
    You can purchse the door seal through our spares shop here , you will need the ENR and FD number which can be found on the inside of the door frame to get the correct one.
    If you are competent DIYer not to bad a job, there are some videos on You Tube as well if you are not sure.
    If you are not sure you can always use our find an engineer here who will carry out the job for you.
    HTH 🙂
    Don
    #401622
    j3lly
    Serial as stated on invioce is
    WAE24363GB1
    Looking around I believe that I need door seal part number
    BS18107
    But cannot seem to find the part number in the lists of Bosch door seals
    Am I missing something
    #401623
    don
    don wrote: you will need the ENR and FD number which can be found on the inside of the door frame to get the correct one.
    Don
    If your’e ENR is WAE24363GB/11 then the door seal is one of these two in our shop.
    Don
    #401624
    j3lly
    had a look on the plate inside of door the number is
    E-Nr
    WAE24363GB/05
    FD 8901 603624
    Sorry for the confusion I got the original number from the invoice
    #401625
    don
    Still the same part number as in my previous post :tup:
    Don
    #401626
    Grumps
    j3lly wrote:Hi
    I see you found your way from the Ultimate Handyman site. 😀
    #401627
    don
    Thanks for your recommendation Grumps on the UH forum very kind of you 😀
    Don
    #401628
    j3lly
    Thanks for the help guys wonderful service
    #401629
    j3lly
    Have changed door seal for a genuine Bosch replacement
    Retaining ring for the door is a solid wire ring with a 80mm ish spring
    The spring does not seem to seat correctly
    Have refitted twice with the spring in a different orientation with the same result
    Have run machine and have NO LEAKS so all good there
    I am just being paranoid about the spring not seating correctly
    Or is there a way of getting it to seat correctly
    #401630
    Andy jones
    Any chance you could post a pic. We could see if it looks ok
    #401631
    j3lly wrote:Iam just being paranoid about the spring not seating correctly
    The spring is best located just below the door hinge area. Seating the spring neatly behind the rubber flange achieved with a little application of soapy water…..’tis all! 🙂
    #401632
    j3lly
    As martin states spring was originally just below door hinge have tried here and 2 other places with the same result
    Here’s a photo as it sits now at 12-00
    Thought this would be best place as less likly to leak
    #401633
    That position is fine!
