Help – Candy Aquaviva 1300, leaking filter !!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Help – Candy Aquaviva 1300, leaking filter !!
  • #40360
    drewb
    The filter on my Washer Dryer has just started leaking. Its a pretty constant drip but nothing major.
    Is there anything I can buy to fix this. I don’t see a rubber seal and was wondering what the best solution would be?
    Thanks for help in advance.
    Regards
    Drew
    #265928
    helo_75
    other than undoing it, cleaning the thing thoroughly, on the filter housing, and where it sits in the pump, no
    and im sure there only the pump unit itself available
    but well need the production number, from the inside of the door
    #265929
    drewb
    Re: Help – Candy Aquaviva 1300, leaking filter !!
    Model number from door is N 37616562 0142 4087.
    To the untrained eye, it looks like something a rubber gasket would fix. I appreciate its not always as it seems.
    Thanks for the reply.
    Drew
    #265930
    06015493 – “filter knob with gasket” appears to available. Contact spares@ukwhitegoods.co.uk for price and ordering.
    drewb
    Thanks for the help. Filter kit ordered.
    I am hoping it is just the screw in plug that needs replacing.
    If I need to replace the full kit, is it an easy job? I dont mind a bit of diy.
    Drew
    #265932
    drewb
    All sorted. Replaced entire filter and no more leaks.
    Thanks for the help!
    #265933
    drewb
    Not quite there.
    Getting a small drip after the spinning cycle near filter. I have sealed the three hoses connected to the filter with Silicone.
    Any ideas of the cause?
    #265934
    helo_75
    there could be a chip out of the pump housing where the seal fits
    ive seen it before
