Help! Can’t find an oven replace existing due to size.
Home Forums Public Support Forums Buying Advice Help! Can’t find an oven replace existing due to size.
  • #91337
    agtmhk
    The existing oven is under the gas stove.
    It is white westinghouse 05-200311.
    It is a lot shallow than the electric oven available on the market.
    I’ve got gas pipe behind which I can’t find any new oven to replace like for like!
    It is about 500mm from front to the pipe at top right.
    So I need an oven to be max dimension as follow. Anyone know if it exist?
    If the only option is alternating the pipe, it will be a bit of hassle.
    #447780
    Re: Help! Can’t find an oven replace existing due to size.
    Get the pipe moved. :tup:
