HELP Diplomat Dishwasher broken, flashing programme light
Home Forums Public Support Forums Help And Support Dishwasher Help Forum HELP Diplomat Dishwasher broken, flashing programme light
  • #26069
    jamjar222
    HELP PLEASE!!!
    My Diplomat ADP 8322, Is broken. The programme button is flashing and the rinse light is constantly on.
    When you shut the door it just beeps at me!!
    My son put washing up liquid in yesterday, i didn’t really think anything of it and turned on the machine!!! Big Mistake!!
    I have removed all the bubbles and water but still not working.
    Could anyone suggest what i should do.
    Many thanks
    Karen
    #208646
    clivejameson
    Re: HELP Diplomat Dishwasher broken, flashing programme ligh
    Most likely you have had a ‘foam-up’ which has overflowed into the base pan in which case you need to carefully tip the machine backwards at 45o and let the pan drain (towels down to collect the water)
    With luck there will be no damage from the water so try it again and let us know how you get on?
    Don’t forget to unplug before you do anything :zap:
    #208647
    jamjar222
    Thanks for such a quick reply, i will try tomorrow, and let you know how i get on.
    #208648
    jamjar222
    We have just tried to tip but no water came out, a bit came out of the white pipe but thats it. We have an intergrated dishwasher, would this make a difference.
    There is still some water in the hole where the filter goes, is this what should drain away?? Or is that allways there?
    Could you suggests what we should do next many thanks.
    Karen
    #208649
    Hi Karen,
    Not such an easy one. 😕
    At a guess, if it’s fun through with washing up liquid, it’ll be a mess internally and need cleaned out, especially the fill chamber and base, transfer tubes etc. before it will work correctly again. I’d recommend some professional help as it’s not going to be a two minute job I shouldn’t think as, while it’s faulted, you can’t run a cold rinse which would help break down the foaming.
