E57 code. I have turned on and off, checked water inlet/outlet, checked service flap (found some coins). Have managed to release door to get clothing out. What next?
Now the machine is empty i would run a drain cycle with the filter out . look insode to see if the pump impellor is spinning , if not the pump has gone, if it is check the waste pipe and u bend . then run the machine again..
