Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › help electrolux oven eso pmss
- This topic has 15 replies, 5 voices, and was last updated 15 years, 6 months ago by
clockworkone.
October 6, 2010 at 4:37 pm #57766
clockworkone
Participanthi have to go to this one saturday, all that works is the oven light, no display so no error codes. any ideas appreciated.p
October 6, 2010 at 4:51 pm #332228Martin
ParticipantRe: help electrolux oven eso pmss
And the Pnc number of this oven is?:con:
October 6, 2010 at 4:59 pm #332229clockworkone
its come through a rental agency all i have is model no and serial no 44606229
October 6, 2010 at 10:42 pm #332230leavemetogetonwithit
From Connect,
ESOPMSS (949711720/00 – 20041022)
ESOPMSS (949711720/01 – 20050610)
ESOPMSS (949711933/00 – 20051021)
ESOPMSS (949712282/00 – 20060602)
ESOPMSS (949712282/01 – 20060630)
Mike.
PS prepare yourself for some nasty electronic nightmare with board at £160+.October 7, 2010 at 9:01 am #332231clockworkone
thanks mike, looks like a recycling job then.not worth throwing that kind of money at a single oven. thought possible safety stat but its the total lack of display thats worrying me will have a look sat anyway.thanks again.paul
October 7, 2010 at 5:04 pm #332232leavemetogetonwithit
Oh yeah, I’d definitely have a look. Customer might be lucky. Also I think these ovens were expensive (£300+?) so could be worth trying to figure out board even if it is that. Posssible that QER or EMW may do them.
MikeOctober 8, 2010 at 10:05 am #332233clockworkone
had a think about this on and was wondering could it be caused by faulty door lock due to it being a pyro oven. had a look on w/diag and showing micro sw on lock.paul
October 8, 2010 at 11:24 am #332234Martin
Nah! I think your earlier suspicion regarding a duff board the more likely reason there’s no display etc. Without that display working you cannot otherwise access the diagnostics anyway so you may be in for a hiding for nothing on this job? 😥
I would hate the thought of you shelling out for a new board, plugging it in and then BANG……..oooopps!
October 9, 2010 at 7:18 am #332235allan73
I’ve got a problem with a similar pyro oven clockworkone the inner glass has been smashed & now the fan’s not running, do you know how the door engages the microswitch ?
October 9, 2010 at 12:33 pm #332236clockworkone
hi the switch is mechanically operated on the lock itself.to be honest am not too familliar with this model myself.tds info very good in fault finding.been out to this one this morn and determined it is the control board that is faulty.checked all stats and elem.looks like some kind of spillage has made its way onto board.checked res at supply and showing(according to tds) that it is the control and not power board. cut off switch on wall by passed so should have walked away but it was rental agency who can supply a bit of work to me. have told them
October 11, 2010 at 9:22 am #332237clockworkone
p/n 949711720. looking for a bit of reassurance on this one before i order programmer.symptoms are no display,evidence of spillage on programmer board,bleep can be heard.tested every thing else power to controller.obviously no fault codes so no way of proving whether any other faults lie in main power board. both programmer and power board expensive and non returnable. supplier has never supplied one of these previously. thinking of writing this one off as too much money for a single oven. dont want to get caught.paul
October 11, 2010 at 7:24 pm #332238leavemetogetonwithit
I would explain it all to the rental agency, that you can’t be sure that they won’t also need a power board and give a provisional estimate that covers you for all eventualities. You could even recommend they or the landlord ring the manufacturers to find out what they’d charge.
Sounds as if it’ll set the landlord back a couple of hundred whichever way he jumps and you will retain their custom by being honest about it rather than pretending you can see in the dark. If they expect their repairer to take those risks then you’re better off not working for them :wink:.
Mike.October 11, 2010 at 8:05 pm #332239gandh1
clockworkone wrote:p/n 949711720. looking for a bit of reassurance on this one before i order programmer.symptoms are no display,evidence of spillage on programmer board,bleep can be heard.tested every thing else power to controller.obviously no fault codes so no way of proving whether any other faults lie in main power board. both programmer and power board expensive and non returnable. supplier has never supplied one of these previously. thinking of writing this one off as too much money for a single oven. dont want to get caught.paul
have u rung elux distriparts direct? ring them on 01325 302464, press 1 for trade and they can sometimes do a one-off price on certain expensive items, like piseybees 🙂
October 11, 2010 at 10:17 pm #332240clockworkone
thanks mike,gandh1 for the good advice.went into rental agency this morning and told them that it was impossible to diagnose power board without programmer working,explained that i would have to give them two quotes and that if programmer rectifies problem all good and well but if not they were commited to carrying out power board replacement. i said i am not willing to be liable for cost of parts if they pull out half way through job. they accepted these terms.
October 11, 2010 at 10:30 pm #332241gandh1
let us know how you get on with this aye?
