Help – Flashing tap light on NEFF S51E50X3GB/46
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Help – Flashing tap light on NEFF S51E50X3GB/46
Viewing 15 posts - 16 through 30 (of 35 total)
  • #465470
    HAD A-NEFF NOW
    HAD A-NEFF NOW wrote:It’s located in here on my machine on the LHS so I take it it’s replaceable without ordering this whole unit?
    https://shop.ukwhitegoods.co.uk/0068…-metering-tank
    So I replaced the Reed switch flow sensor after it arrived yesterday. Switched the machine on and no change. I still get the flashing tap light and no machine functions.
    I did notice internally on the metering tank that a section is discoloured and has a loose piece possibly a seal on the side. Can you identify what this is and what its purpose is? Its integral to the sealed tank so I couldnt gain access. I’ve tried uploading a pic but it doesnt allow me to due to file size. If you look at the metering tank link you sent in the pic it’s the black square unit at the top 12 o clock position. This and the surrounding plastic is now pink on my metering unit
    I’m lost here. And cant keep replacing items that dont rectify the fault.
    Help!!!
    #465471
    HAD A-NEFF NOW
    iadom wrote:In the pub atm so not sure if this will get through. A very common fault with exactly those symptoms.
    I did notice internally on the metering tank that a section is discoloured and has a loose piece possibly a seal on the side. Can you identify what this is and what its purpose is? Its integral to the sealed tank so I couldnt gain access. I’ve tried uploading a pic but it doesnt allow me to due to file size. If you look at the metering tank in my link i posted in the pic it’s the black square unit at the top 12 o clock position. This and the surrounding plastic is now pink on my metering unit
    #465472
    did you check the wires from the flow meter to the board. had wires eaten by mice last year causing same fault
    HAD A-NEFF NOW
    I checked the visible wiring all looked fine. Mice are a long shot theres no evidence of mice droppings anywhere on the floor or integral to the machine
    #465474
    worth a try
    if wiring is ok and connection is solid to the board and water flows in when unit starts then could be a board problem
    HAD A-NEFF NOW
    The machine does absolutely nothing no water fill no pimp noises theres no function. Just the red tap light just flashes constantly. My 1st post describes the issue in more detail, and also what I’ve changed as I’ve gone along. If I change the board is it a straight swop out no soldering required
    #465476
    so I assume the part you replaces was the inlet hose with the valve on the end
    the red light comes on because no water is flowing in so we have to figure out why
    first are you sure the tap is on. get a lot of these taps that move but don’t operate so if your not sure remove hose from tap and blow some water out of it to make sure
    what happens now when you start a programme ?
    the pump should run for a bit , then stop, I then expect it to fill
    you could measure the voltage being fed to the fill valve to see if the board energises it. its a 240V mains valve
    HAD A-NEFF NOW
    electrofix wrote:so I assume the part you replaces was the inlet hose with the valve on the end
    Hi Dave
    yes I replaced the inlet hose with the water sensor attached to it. I was hopefull this was the issue but it had no effect.
    The water supply tap itself Is fine it has ample pressure and the flow is there as well
    I cant select any program functions whatsoever. The flashing tap light is hard fault and prohibits any program selection so I have no operability.
    Happy to diagnose electrically if you can help me out.I have a fluke but am a novice to using it.
    Cheers Steve
    #465478
    well that’s odd for a start. you have a fault light but it wont start
    and if you press and hold the start button to reset what happens ?
    well just read owners manual (always best place to start )
    if the water light comes on its a fill problem
    if the water light flashes its a technical problem and not necessarily a water problem and more like a general fault code. does the light have any pattern to it ? like 5 flash stop 5 flash etc
    any other light lit at the time ?
    what we are looking for is some sort of fault code we could go looking for. Neff info is not easy as they restrict it
    HAD A-NEFF NOW
    electrofix wrote:well just read owners manual (always best place to start )
    Hi Dave
    Thanks for the reply. Oh I looked at the manual but didnt spot that.
    Theres no pattern to the flashing light, it just continuously flashes. Initially the lower light was also on for the rinse aid but this has since cleared. Probably a bi product of the hard fault in any case.
    I’m out the rest of today but will get back to you tomorow. I appreciate the help.
    Cheers Steve
    #465481
    BarryD
    I also have this problem with a NEFF S5IT69X2GB51 – the water light just flashes and pressing buttons has no effect.
    Does anyone know if this problem was eventually resolved and if so what the culprit turned out to be ?
    Thanks,
    Barry
    #465482
    all this tells us is that is has a fault but does not pin it down
    are there any other lights on or flashing ?
    BarryD
    Hello Dave,
    I should have been a bit more explicit – the symptoms seemed to be exactly the same as posted by ‘had a-neff now’ before he started changing things.
    However I can’t remember for certain if the all the LED’s behaviour have always been identical but the situation now is:
    Pressing power on button: After 5 seconds the water and rinse aid LED’s both start flashing constantly at about 2 flashes per second. The middle LED stays off.
    I seem to remember when it was working it goes clonk a few seconds after powering on, like a solenoid activating. It doesn’t do that now.
    Pressing the power on button again turns all LED’s off.
    All other buttons seem to have no effect. I have tried short presses, long presses, very long presses, double presses and some combinations of button presses too – Nothing changes unless one of the buttons pressed is the power on button.
    Filling the rinse aid had no effect on the rinse aid LED as would happen normally.
    I have also tried unplugging for 5 minutes and try again but this also had no effect.
    Barry
    #465484
    from what i can see, the instruction manual says your has a display so if it had a fault code it would come up E06 or similar
    has yours got a display ?
    try checking the base for water flooding by either tilting it back slowly to 45 degrees or removing cover below the door and checking for water
