Help for Bush DWFSG126B dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Help for Bush DWFSG126B dishwasher
  • #92571
    bbfn2001
    Would appreciate help with a dishwasher. Basically dishwasher is only out of packaging 1 week ago but out of warranty by a month or so as it has sat in garage until install.
    It worked fine the first few days but now program button doesn’t work although all rest of buttons do. The program button did work if you pressed it slightly harder, but now has stopped altogether. The control board and contacts all look good as does the buttons. Any idea? (see attached photo)
    Thankyou
    #451598
    1totalshambles
    Re: Help for Bush DWFSG126B dishwasher
    Looking at the picture the bottom row of micro switches look bent relative to the top row which would equal fractured solder pcb joints caused by the whole pcb within its plasic support frame not being attached to the facia plastic panel. Have a very close look and see if there are fractures in the switch legs and if so it might be repairable?
    #451599
    bbfn2001
    Thanks will have a closer look
