Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Help, Hoover eco wave a1110 sticks on wash ??? advice needed
- This topic has 11 replies, 2 voices, and was last updated 11 years, 6 months ago by
stin74.
September 17, 2014 at 11:08 am #82259
stin74
ParticipantIve had this machine about a year, its fairly old but a good, machine, takes hot and cold fill and fills to a decent level which i like unlike some newer machines that use less water.
Anyway, i tend to always use a 40oC wash, progam 4 on my machine
Recently when i start the program it will heat the water as usual but about 5 or 10 mins into the program the dial control is sticking and not moving on. I am manually having to turn it to the next stage in the cycle when it completes and works as normal
I am out of work at the moment and have been for a while so money is tight and ive just had a fine to pay so im not in a position to really get another machine, and i really like this machine too….som is there anyway this can be fixed ? As its old i guess parts arent likely, and if available pretty expensive ?
Is it the timer mechanism thats likely ? Ive tried taking the dial off and cleaning around it incase it was lodged with dirt etc but it hasnt helped.
Any useful advice on how to proceed appreciated 🙂
September 17, 2014 at 12:00 pm #419335Martin
ParticipantRe: Help, Hoover eco wave a1110 sticks on wash ??? advice ne
A closer look at the heater and thermostat would be your next move. (Access via front panel removal.) I don’t believe it is the timer at fault (at this stage anyway) because the timer drive switches off during the heating phase and relies on the thermostat to advance it to the next stage (which you are doing manually right now). Timer most probably OK I would think.
Let us know how you get on. 😀
September 17, 2014 at 4:54 pm #419336stin74
Martin wrote:A closer look at the heater and thermostat would be your next move. (Access via front panel removal.) I don’t believe it is the timer at fault (at this stage anyway) because the timer drive switches off during the heating phase and relies on the thermostat to advance it to the next stage (which you are doing manually right now). Timer most probably OK I would think.
Thanks for the reply and advice
Is it the heating element itself i need to check ? Is the thermostat near there ? Will there be visible signs of wear or can it be checked with a multi meter etc ?
September 17, 2014 at 5:24 pm #419337Martin
Yes, yes, no and yes, in that order. 😀
September 18, 2014 at 10:45 am #419338stin74
Martin wrote:Yes, yes, no and yes, in that order. 😀
Does the heating element itself contain the thermostator is it near by? If so do i need to replace to whole element that slots in to the drum ? The water is heating up.
September 21, 2014 at 5:47 pm #419339stin74
I guess im probably just replacing the heating element ??
September 21, 2014 at 5:55 pm #419340Martin
stin74 wrote:I guess im probably just replacing the heating element ??
No point in guessing, that can be a costly waste of time and money. Have you tested the heater?
September 21, 2014 at 6:00 pm #419341stin74
Martin wrote:
stin74 wrote:
I guess im probably just replacing the heating element ??No point in guessing, that can be a costly waste of time and money. Have you tested the heater?
Not yet, it heats up ok though, i did a load last night and it heated up with was essentially a cold feed because there was no hot water going on. The hot water in the house was off.
So do i need to test the thermostat/thermister ? And how ?
September 21, 2014 at 6:12 pm #419342Martin
stin74 wrote:So do i need to test the thermostat/thermister ?
An obvious stage in the diagnostic process I would suggest.
stin74 wrote: And how ?
It’s a basic (and very reliable for the most part) stat that is N/C at ambient, so an easy continuity test will suffice. The connections from it to the control board are more the relevant especially if the module is the old timer driven board that sits on the sub-frame? The terminals on those old girls are subject to lots of corrosion.:(
Good luck with that :tup:
September 21, 2014 at 6:17 pm #419343stin74
Martin wrote:
stin74 wrote:
So do i need to test the thermostat/thermister ?An obvious stage in the diagnostic process I would suggest.
Im not sure to do that, im quite handy at picking things up when im shown, but not sure on this ! I do have a meter, though never used it ! doh.
I thought maybe i could take the themostat out from the element bit and test it in hot water or something ? 😀
September 21, 2014 at 6:38 pm #419344Martin
It’s not in the heater. It sits alone adjacent the heater.
September 21, 2014 at 6:43 pm #419345stin74
Martin wrote:It’s not in the heater. It sits alone adjacent the heater.
Thanks.
