Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Help ! I’d best get to bottom of codes !
- This topic has 5 replies, 4 voices, and was last updated 17 years, 2 months ago by
sparepart.
January 11, 2009 at 4:32 pm #42490
sparepart
ParticipantHi All, I know i’ve asked before but i’d better teach myself to read these WF and WD codes ! so can someone help me please ? On a WD we have 5 neons on the left going down and 5 across the top plus Off/on Neon ? so say I have the reduced crease neon flashing and the on/off neon flashing , so thats obviously the second neon down but how do you count it on the error codes ? …….sorry to ask but I hate these machines there just carp ! and what is the reduced crease and on/off flashing supposed to mean anyway ? I am trying to learn so as not to bother you good people !
AlanJanuary 11, 2009 at 4:49 pm #273690stripey
ParticipantRe: Help ! I’d best get to bottom of codes !
Error Codes
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power boardSo in this instance with the second light flashing the error code would be f04 light 2. pressure sw stuck on empty.
HTH
January 11, 2009 at 5:22 pm #273691Penguin45
ParticipantJanuary 11, 2009 at 5:41 pm #273692sparepart
Thanks Stripey, its a start ! problem is the motor dont go into full spin , yes I understand pressure switch and swapped it with no result as thats how I read code ? did that earlier on today so thats why I ask if I’m reading codes wrong ?
Hi penguin. I really understand what you are saying and I even have the error codes laminated in my book but its no good if you dont understand or are reading it wrong , just wanted help in trying to understand it thats all and I know its a stupid question to most but I hate these machines but its no good me shying away from it ? just wanted help in the thing ……other machines I do understand , maybe a few brandies would help ?
Thanks Alan
January 11, 2009 at 6:21 pm #273693Penguin45
😀 I can do the Hotpoint/Indesit ones – it’s the Zanussi ones that drive me up the wall…… :rolls:
January 12, 2009 at 8:39 am #273694Martin
sparepart wrote: but its no good if you dont understand or are reading it wrong , just wanted help in trying to understand it thats all
I’ve tried to explain in the last thread you raised sparepart. If you click your mouse on THIS LINK and read the last post it may help you once more? 😉
