A while ago our machine failed, motor sparking and weak, brushes had failed. I bent the brass terminal a little bit to allow the carbon to come out a bit further, so the machine would run while I ordered new brushes.
Yesterday I decided to fit the new brushes, no problem, the machine ran fine at first, but did not complete the cycle, stopped on final rinsing. No lights on the panel. Checked plug fuse, socket, ok. Nothing looks burnt, no smells.
I could get a new mains suppressor easily so I changed that, no different.
There is a live to the green wire on the door interlock.
Does this interlock cut the power to everything? Can anyone tell me how to check the door lock? Or what to check next?
Many thanks!!
