Make/model: Indesit WIXE 127 ES
Symptoms:
1. If unplugged from wall plate and then reinserted and started the machine always starts in TEST mode. After the test mode which runs for about 30 mins and everything seems OK it goes to flashing END.
2. If I choose any program and press START the machine goes to flashing END in 1 second, the door lock does not even light up.
3. No error is displayed.
I did replace the 24C64 eeprom after successful reprogramming but the machine acts exactly the same.
What should I do next?
