Help: Indesit IN CB310 UK fridge partially freezing
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Help: Indesit IN CB310 UK fridge partially freezing
  • #103205
    sniktaw
    16 year-old Indesit integrated fridge freezer IN CB310 UK working until 3 weeks ago.
    Fridge partially freezing. Salad drawers freezing items and back wall partially iced over.
    Freezer OK. Door seals OK.
    Thermostat has never been adjusted, always set to #1 i.e. warmest.
    Have tried defrosting.
    Should I try changing the thermostat?
    thanks in advance.
    #492194
    if its the old type none electronic thermostat then t will probably cure it
    Daev
    #492195
    To be sure you’d really need temp readings from the freezer as I suspect that it’s running too much from what you describe but, is it the thermostat or something more nefarious
    sniktaw
    it’s this style thermostat.
    I’ll try to get some freezer termp readings.
    #492197
    If the unit is running all the time it’s probably the thermostat, it just depends on how cold it’s getting really as at times they can do weird things.
    sniktaw
    Have placed the bulb of a thermometer in oil and placed it in the salad drawer. One hour on and it’s -2C.
    Guess I’m really asking: £50 to replace thermostat or call it quits on a 16 year-old unit and replace it?
    #492199
    To be fair, that’s a good question, and if it were me, I don’t think I’d spend that on a unit that old.
    sniktaw
    Agreed, thanks
