Help instaling a philco DN500 Timer on a dryer
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Help instaling a philco DN500 Timer on a dryer
  • #89948
    Plugber
    hi everyone, i have a philco machine DN500/A that had a bad timer i purchased a new one but now i dont know the way its connected.
    anyone know about these machines?, i would be thankful.
    here are a few pics of what i am talking about if it helps.
    #443109
    Re: Help instaling a philco DN500 Timer on a dryer
    cant see the other side of the timer.
    in hoover timers of a similar type the used to put coloured blobs to helps get things in the right place
    Plugber
    thank you very much for replying Dave,
    i am sorry its not crystal clear but if necessary i will get a better quality shot.
    #443111
    It’s clear from the photos that the respective connector blocks fit on the corresponding terminal (e.g. The one connector block with just 3 tags plugs into the single bank of 3 tags)
    #443112
    Plugber
    thanks for replying Martin,
    checking at the blocks and the way they are packed looks to be something like this;
    the slots aint all filled in the blocks there are a lot of connections that aint being used so it gets a bit harder, the yellow one seams easy, in the middle and by the way the other blocks are and the position they got for over the years by being in the same place i assume as we see them i just have to put the timer in place and slide them right up, the red one have connections in one side and the green in the other side.
    still by logic or assumption since i am not an expert i decided to post.
    i will get some better shots of those blocks.
    thanks.
