Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › H=e=l=p – its 18 degrees in fridge
- This topic has 7 replies, 2 voices, and was last updated 12 years, 5 months ago by
coolpoint.
November 25, 2013 at 9:13 pm #78315
coolpoint
ParticipantIts Hotpoint FF72P
Can anybody tell me what components i should replace 😕November 25, 2013 at 9:46 pm #405208Martin
ParticipantRe: H=e=l=p – its 18 degrees in fridge
coolpoint wrote:Can anybody tell me what components i should replace 😕
Try sticking one of THESE in. You never know, it might sort it?
November 25, 2013 at 10:04 pm #405209coolpoint
Thx Martin.
What about the thermistor in the fridge section (white plug that goes into the PCB i think)and the second thermister in the freezer.In the freezer, I think there is one with a yellow plug and one with a green plug.
November 26, 2013 at 8:46 am #405210Martin
coolpoint wrote:What about the thermistor in the fridge section (white plug that goes into the PCB i think)and the second thermister in the freezer.
Yeah why not GO FOR IT and cover ALL OPTIONS 😀
November 27, 2013 at 11:59 am #405211coolpoint
Thanks Martin.
Is there anyway I can view the service manual.
I am going to replace the yellow plug thermistor C00293529 Evap thermistor. If this does not fix, than I need to look at next part or parts to replace.November 27, 2013 at 3:25 pm #405212Martin
coolpoint wrote:Is there anyway I can view the service manual.
The manual is now out of print but maybe eBay? The part number was :C00220861
November 28, 2013 at 2:53 pm #405213coolpoint
Thx again Martin.
Fitted the new thermistor in yellow plug position.
It was an insulation displacement connector.
There were no error codes on power up.
I am going to trial it for 3 days to see whether the old problem of a warm fridge re appears.
its at -22 deg c freezer and 3 deg for the fridge at present.
Fingers crossed.December 2, 2013 at 8:44 am #405214coolpoint
Its now Monday 2/12/13.
The fridge has settled down to 2-5 deg c now.
The freezer is at -22 deg C
Changing the yellow plug thermistor has sorted my fridge out.
Fingers cross.
Does anybody know if I can fix -22 deg. I think it should be at -18 deg. There are no adjustments on the freezer section. Only fridge temp can be set. Is it another thermistor.
All the best to everyone for the season ahead. -
