Re: HELP – looking for island hood suitable for low ceiling
If you have space you could also use a downdraft extractor, it could be an option but it too is not a cheap one. From memory I believe that Elica do that as well.
I’d have to check the rest of the ranges to be sure of the minimum heights that the hoods can drop but, from memory the hood must be at least an absolute minimum of 650mm from the hob if it’s gas and 600mm for electric. Any less that that and you will have problems.
HTH
