Hi I have a job to replace the hinges on a Rangemaster 100 RH oven, it has beko spares.
I know the hinges have 2 screws fixed in the side and can remove the panel on right to get to one hinge but does anyone have advice how to get to the LH hinge which is basically in middle of oven. I can only imagine that the whole oven cavity somehow slides out to gain access.
have seen on pic of an oven repair where a massive strip down was needed to get at a particular part so i know it happens. cant say on this one as i would probably walk away from it
