HELP MOANING FAMILY ALL BECAUSE OF HOTPOINT 1200 WD32
Home Forums Public Support Forums Help And Support Washing Machine Help Forum HELP MOANING FAMILY ALL BECAUSE OF HOTPOINT 1200 WD32
  • #25757
    CharlieMAX
    I need help so badly. I’m pretty good at mending the damn machime but this time i think i need advice.
    The problem is the machine is filling, turning washing………….but when it gets to drain. rinse, spin nothing!! nothing at all, the turn knob thing just keeps clicking through and the drum keeps turning.
    Last week i put my son’s aqua mat in just to clean it with No soap and i thought the devil machine didn’t read anything in it. So i ended up forcing the door open and busting the latch. But i went out and brought a replacement latch and mended it then thought ok i’ll put a normal load through and damn devil blasted thing has done it again.
    I really can’t afford for a repair man to come out and also a laundrette is out of the question due to no dollor.
    I have moaning people with no clean clothes and my hands are getting soar.
    I WILL DO ANYTHING FOR HELP ADVICE EVEN JUST TO READ A MANUAL
    DESPARATE WOMEN WHO WILL BEAT THE BLASTED THING TO HELL!!!!!
    :taz:
    #207485
    Re: [b]HELP MOANING FAMILY ALL BECAUSE OF HOTPOINT 1200 WD32
    Ah the joys of washdays eh Charlie?
    The pump is at fault in your case, lower the drain hose to the floor and the water should flood out (have a bucket ready) Then you’ll need to open the door and retrieve your soggy washing. Close the door back up, take off the back panel and take the pump apart. 😉
    :zap: Remember to first disconnect your machine from the power? otherwise its bye bye Charlie! :zap:
    #207486
    CharlieMAX
    Re: HELP MOANING FAMILY ALL BECAUSE OF HOTPOINT 1200 WD32
    :bounce: Wow that was quick 😆
    Thankyou so so so so much xxxxxxx I shall try your good cop approch to it and hopefully it will be kind to me, but oh yes first wash up and make room to pulll it out.
    I shall be back once done either loving you or crying to you
    #207487
    CharlieMAX wrote:Hi again Going good so far!!!!!!!!!!!! 😆
    4 buckets of water and the door has opened 😯
    Now then i’m going to go in to the machine now to get to the pump!!!
    :lesson: What should i be looking for when i get to the pump. Really don’t want to cock this up 🙁
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    Keep it in one thread, Charlie, otherwisw we all get confused. :conf:
    Remove plug. Remove rear cover. You will be able to see a hose coming down from the bottom of the drum. It contains a filter which may well be choked. Follow the hose and you will find the pump. Small objects can get through the filter and lodge in it, so you may need to remove the pump and see what’s inside.
    CharlieMAX
    😕 Plug 😕
    At the top on the back is a black rubber thing, a bit comes out so would the be the plug or is it inside
    #207489
    CharlieMAX
    oh yes sorry electric plug already un plugged from drainage.
    thought you meant another plug like a sink plug or something 😳
    #207490
    Safety first…… 😀
    CharlieMAX
    :haier: :haier: 👿 👿 👿 😈 😈 😈 😥 😡
    Any hints of how to get a threaded, twisted and rusted screw out!!!!!!! would ask the other half but he’s watching football and he is annoyed that the tools and well he can’t get in the kitchen
