Help! My Service 1100rpm washer/drier has died
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Help! My Service 1100rpm washer/drier has died
  • #12337
    Sloshy2004
    It’s out of guarantee, but hardly been used. First, starting from ‘mixed load’ program, it began stopping (not pausing) just before rinse/spin – it used to rinse/spin at the end of this progam 😥 . So, I began THEN manually putting it on a separate ‘rinse/spin’ program – hey presto, it worked 😀 But only about on four consequtive ocassions 😥 Sudennly, the power light on the machine went off altogether, and everything died 🙁 AAh – the fuse on the wall connector, or the house circuit breaker’, I thought. But NO, both are fine. The machine is full of water, as I found out when I opened the door to retrieve my clothes 🙄 Anybody any idea what the problem could be – I am on DIsabled Living Allowance (ie very little), so I wonder if anyone has a vague idea of how muich it might cost to get fixed? Or if I could even fix it myself? MAny thanks.
    #149192
    andy2
    Re: Help! My Service 1100rpm washer/drier has died
    Hi Sloshy2004
    If the electric supply to your washer is ok then the fault could be in several different areas ranging from a wire off to a faulty electronic module. Without a degree of expertise to be able to trace through the various circuits you are going to be struggling.
    Your original fault probably is related but it may be a 2nd unrelated fault.
    Consider getting some help if you can on this.
    :zap: If you do have a look yourself make sure you remove the appliance plug BEFORE doing anything else. :zap:
    Regards – Andy 🙂
    #149193
    Washman
    HI
    Whats the model number it can be found on the filter flap at bottom right this will help us help you
    Mike
    #149194
    Sloshy2004
    Thanks for advice, Andy. Mike, I opened the hinged plastic flap on the bottom right hand corner of the machine (there’s a plastic screw-in thing behind it) – the only number on the back of the plastic flap is 2/2, seems too short to be a model number? It’s next to a triangle (British Kite Mark, I think), with >ABS< underneath. Am I looking in the right place? Thanks, Nev
    #149195
    Look on the back panel near the worktop lid for the number for us then Sloshy 😀
    #149196
    Sloshy2004
    HEY GUYS!!! Thanks loads (washing machine loads 😀 ) for your help and suggestions. I have just accidentally found the fault!! It is the the door switch. I waggled the door around (a plastic, flimsy thing), and suddenly, all started working again 😀 Quite what wil happen when it gets to the end of the cycle remains to be seen. Best wishes all, from Nev
