Have moved into a property with this built oven and have no manual. The control dial is confusing, it has the temperature graduations up to 250, then two symbols which seem to indicate the lower half and the upper half of the oven. This is followed by a symbol for the grill, which I have tried to use, but always blows the main fuse. The oven heats well but seems to be excessively hot at the bottom, as a result anything on the middle shelf or lower burns from the base up. I have tried to download an Instruction For Use from this site but to no avail. The details on the ID plate are IGNIS AKL 381, CA 921400073 and Code 15010. Would appreciate some help from someone out there. Many thanks, Kathy.
