Help Needed
  • #96695
    Grantb
    I have a hoover dynamic next washing machine model number dead 48w3-80 and the machine keeps filling with water continually I have just replaced the water inlet valve and have the same issue. Again looked on line and advised issue could be with the pressure hose however the machine does not have a pressure hose can anyone assist?
    #464478
    Grantb
    Sorry that is dxa not dead
    #464479
    It does have a pressure hose, inside the machine connected between the pressure switch and a small chamber on the outer drum. If the water continues to fill when the power is switched off then the valve and nothing else is at fault. If it continues to fill when switched on then a problem with the pressure switch, pressure hose or the pressure chamber is the likely culprit. It can be due to a small hole worn in the rubber pressure hose, a blockage in the pressure chamber or hose or a faulty pressure switch.
