help needed on whirlpool oven f3 fail, cant program new modu
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries help needed on whirlpool oven f3 fail, cant program new modu
  • #93536
    MANDELLS
    Hi guys, i have a problem with a whilpool fan oven model number akzm 655/1x 852565538000 where the grill element stays on as long as the mains plug is on, pretty sure its a stuck relay on the pcb board anyway i ordered a board from connections they said that it was part number 481010471409, i fitted it but it came up with f3 failure straight away, after very kind advice and email from dave on here i proceded to try and program the module, it seems that the module covers a range of dfifrent spec models, acording to my model i have to hold the ok button down for 5 seconds before it goes into program mode, unfortunately i cant get it into to program mode unless i hold down the ok and forward button then as in the picture it seems its in program mode for a different rang oven,
    Have i got the wrong module?
    Am i doing something common wrong? Any help much appriciated,,
    #454717
    MANDELLS
    Re: help needed on whirlpool oven f3 fail, cant program new
    Another photo
    #454718
    MANDELLS
    The module i have been sent
    #454719
    Hollytree_Technical
    I have not dealt with these ovens myself but looking at the manual it suggests that you need to turn the “Test” bit on and if it comes up with F03 to make sure that the configuration code is correct and that the test bit is on then wait 10 minutes.
    Jem
    #454720
    MANDELLS
    hi, can anyone tell me the configuration code please as when I get it in to set up mode
    it only give me the option to enter a u number and nothing else, thanks
    #454721
    you have all the info on this
    configuration code on last page of manual but starts with N
    look page 9 of manual re config codes
