Help needed samsung rs20ccsv
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Help needed samsung rs20ccsv
  • #62656
    PrincessD
    The temperature light for the freezer was flashing and when I looked in side most of the food was defrosted. I removed back panel inside and it was really iced up. Should I defrost and turn back on or Could there be a problem with the sensor. 🙁
    #350827
    Applianceman2010
    Re: Help needed samsung rs20ccsv
    Yes defrost for 24hrs and turn back on, if the problem re occurs get someone out to check it out 😉
    #350828
    The defrost sensor will be a failure in the freezer section..It will fail again and stop freezing.
    Bryan
