please can anyone give me some advice with the diplomat 8703 washer/dryer. I have recently inherited this machine when i moved into a new flat. The washer seems to work fine but cannot get it to dry any clothes. I have tried every cycle possible and have even halved my load to see if this helps. I have a user guide but that does not help me at all. am i putting it on the wrong dial setting as the machine does not seem to give off any heat.
Thank you
That appliance is made by Hoover/Candy. It has 2 resettable stats on the dryer casing but they are prone to nuisance tripping. There was a modification to replace the thermostats with higher temperature ones and also replace the NTC to prevent this reoccurring.
