Help needed with Whirlpool Washing Machine.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Help needed with Whirlpool Washing Machine.
  • #44263
    Tigerplank
    Hi, My washing machine is a Whirlpool 6th Sense, 1100 spin, AWM 6110/3 & in the last 2 weeks it has been making a terrible racket when it’s in a spin.The Noise gets worse as it nears the end of the wash ( Like a banging noise ).Any Ideas what the problem could be as I’m going to open it up & try ( gulp ) to sort the problem.Any help very welcome…thx
    #280400
    suedehead1
    Re: Help needed with Whirlpool Washing Machine.
    could be the bearings or a broken drum spider or foreign object, plug out first of course.
    #280401
    Tigerplank
    suedehead1 wrote:could be the bearings or a broken drum spider or foreign object, plug out first of course.
    Is this hard to fix ? Would it be easier to just buy a new machine ?
    #280402
    suedehead1
    it would be a good idea to call out someone from repairs@
    #280403
    Tigerplank
    OK I’ve opened the top of the Machine & noticed a large Brick with 2 metal rods on it & both Rods & the Brick are Snapped.Why would they snap & can I buy this Brick with the Rods ?
    #280404
    suedehead1
    the concrete weight breaks because the bolts loosen off, i would check the fixing brackets where the bolts go, if they are damaged the machine is not worth fixing, the concrete weight and bolts are available as spare parts.
