Help new printer
Home Forums General Trade Forum Help new printer
  • #40092
    kladave
    We need a new printer for the business,we have at the moment a hp colour laserjet 1600 which is a bit of a big beast as we use the printer alot
    but what i need to know is there a printer on the market that uses affordable cartridges.It is cheaper for us to buy the same model cheaper than buying x 4 cartridges £149 plus the vat.
    These £30/£50 printers are no good either,we don’t mind paying for the right kit.
    hotpnt
    Re: Help new printer
    hi, i use an Epsom, (always easy to get cheap carts for those) its a DX8400, printer/scanner, sits neatly on the desk, plus it connects into the broadband box so you can send items to print off from any pc/laptop in the house without needing to connect it to the pc
    #264739
    Epson here too (RX685 scanner/printer)….brilliant piece of kit. Works independent of PC also 😀
    #264740
    Dales-Electronic
    If its a printer only you want why not consider a colour laser – you can get a Samsung 300 series for less than 100 quid.
    #264741
    AMS
    I use a brother all in one machine, and quite honestly it’s the best printer I’ve ever had. Dirt cheap to run too. You can get 6 cartridges (compatible) mix and match for £15.54 from rubberfrog.com. Never had any blocked printer heads, unlike the Epsons that I had used for years and got increasingly frustrated by.
    kladave
    Thanks for the replies folks
    we have decided to go for the same model,as the ‘old’ unit is way out of guarantee and to my memory it has never jammed,a problem we used to get on other printers.
