HELP PLEASE
  • #31153
    mickymunn
    HI all new member so sorry if i have posted in wrong section.
    I have a bosch freezer under counter type and just came back off holiday today and the inlaws who were staying pet sitting say they saw water leaking out. It was defrosting. The lights all work on the freezer and the fast freeze light works but its not getting cold? is there something i can do or is a part that has failed?
    Thanks guys
    #229898
    gegsy
    Re: HELP PLEASE
    If it there is no sound from the motor on the rear when the fast freeze button is activated than Im afraid its possible the motor/compressor or start unit may be at fault.
    If you need pro help please use the link below 🙂
    Without a model from off the appliance itself all the above is hypothetical though 😉
    mickymunn
    Re: HELP PLEASE
    Hi Thanks for the reply, i have just tried turning the fast freeze on and it made no sound. The model is Bosch Logixx and the model munber i think is GSL1240GB/01. would you have any idea on the problem and also a rough idea of the cost to repair as it is only 4 yrs old
    #229900
    gegsy
    Re: HELP PLEASE
    Could you check the model number, Im guessing GSL12420GB/01 😕
    mickymunn
    Re: HELP PLEASE
    Hi Greg yes that is the model number, i did post it in the previous reply.
    #229902
    gegsy
    Re: HELP PLEASE
    Yea but you missed a 2 😛 😀
    The appliance is a basic freezer so it may have a faulty switch bank or as my previous post a compressor system fault.
    IMHO you would be better seeking pro help 🙂
    mickymunn
    Re: HELP PLEASE
    Thanks for your reply, as you say its a basic freezer, in your opinoin what would you expect to pay to get it repaired? or do you think it would be worth just buying a new one? I know you cant really tell what is wrong with it but with the two possible faults you have described what do you think the cost would be?
    #229904
    gegsy
    Re: HELP PLEASE
    At worst it could be the compressor complete job approx £200 ish
