help please – at wits end finding PCB’s for hotpoint washer dryer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum help please – at wits end finding PCB’s for hotpoint washer dryer
  • #103047
    SJHarris
    we have a Hotpoint washer dryer, model RD1076JD UK
    it turned itself off and won’t turn back on again. we had an engineer come look at it and he said it needed a noew main PCB and a new display PCB
    the machine is just over 5 years old and just outside it’s warranty. they told us that the PCB’s are now obsolete and we should try and get some from a parts company, but they need to be pre-programmed, because their engineers can’t flash them
    so i have two problems
    1) i don’t really know what i’m looking for and the repair company won’t put me in touch with their engineer to ask him
    2) the parts sites don’t say whether the PCB’s are pre-programmed or not and they can’t/won’t answer my queries about them
    i’ve found these…
    https://www.partmaster.co.uk/hotpoint/rd-1076-jd-uk-f100283-769991002833/main-pcb/product.pl?pid=5274978&path=66991,52516:66992&model_ref=15148703
    https://www.tfspares.co.uk/product/main-control-pcb-for-hotpoint-rd1076jduk-washer-dryer/
    https://www.partmaster.co.uk/hotpoint/rd-1076-jd-uk-f100283-769991002833/display-pcb/product.pl?pid=5337931&path=66991,52516:66992&model_ref=15148703
    can anybody tell me which of the two main pcb’s i’ve linked to is the right one and if the display pcb is correct?
    also, can i assume because it doesn’t say anything on the website about it, that these are pre-programmed boards? if they’ve come out of an existing machine, that’s seems like a reasonable guess…
    i’m at my wits end with this, so i’d really appreciate any help you can give me!
    many thanks!
    #491597
    try
    https://www.qualityelectronicrepairs.co.uk/
    they can repair some boards
    I think the engneer has quoted for both board as he does not know which one is the problem
    also to look any spares you will need the commercial code and serial no off the label
    https://www.hotpoint.co.uk/spare-par…pSQ6oJk4SSrmnj
    #491598
    SJHarris
    thank you. they gave us this code – 805281156 – but it doesn’t seem to have enough digits. the ones i’ve seen have 13 digits.
    thanks for the link, i’ll see if i can find it
    #491599
    SJHarris
    ok, so i think i’m going to try and remove the pcb’s and get them repaired. i’m ok with the tools, so i don”t think it will be too difficult for me and i’ve found a couple of vids that will help.
    #491600
    the commercial code is on the label inside the door and sometimes repeated on the rear
    SJHarris
    thanks for the help. i managed to remove it and send it to the repair company. fingers crossed.
    #491602
    SJHarris
    ok just for info if anybody else has the same problem. i found this
    https://www.youtube.com/watch?v=J5PTCKzp2kI
    looks easy, but believe me, it isn’t. almost broke me, gotta be honest.
    #491603
    it gets easier the more you do but putting it at the bottom has lots of negative about it
    they put it in before the tub so its easy for them, for us its hard to get at, it can get condensation on due to cold air at floor level and add to the fact thats its well placed for slugs to get into and and i have had quite a few damaged board because of that
