Help Please! Bosch Auto WAE24162UK/01 Shockers Replacement
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Help Please! Bosch Auto WAE24162UK/01 Shockers Replacement
  • #90452
    laurenceuk
    Never had to replace shock absorbers on Bosch autos before.
    On this model the plastic pin attaching the shock to the tub seems permanently fixed. The new shocks contain a terribly poor quality photo copy of a diagram showing how they are fitted and scant poorly translated instructions – can’t make head nor tail of it. 😕
    It seems some drilling has to take place and the tub is shown outside of the casing.
    Can anyone throw light on this replacement procedure please?
    Many thanks,
    Laurence
    #444852
    kaibart
    Re: Help Please! Bosch Auto WAE24162UK/01 Shockers Replaceme
    You need a 13.5mm drill bit and you drill the hole through where the existing plastic peg is you do need to remove front panel to do this and I remove pump and sump hose for easier access do 1 end at the time Bosch have now changed the kit so you use a plastic peg instead which I haven’t used yet but that’s ho you do it 😉
    #444853
    laurenceuk
    Thanks Kaibart,
    Really appreciate your quick response.
    Thank you.
    Laurence
