Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Help replacing bottom element in Kenwood CK480
- This topic has 6 replies, 6 voices, and was last updated 18 years ago by
Rob_Spalton.
March 16, 2008 at 2:05 pm #35327
Rob_Spalton
ParticipantAlthough heating up, oven wasn’t getting up to full operating temperature when used in fan-assisted convection mode and I have diagnosed that the bottom element has died. I’ve taken the back off and checked the element with a meter and it is open circuit. Before ordering a replacement element, I have been trying to get the base panel out to see whether I can fit it myself (and to check what the element looks like for ordering) with no success.
Three screws removed from the front, three from the back, but no apparent way to lift/prise out the base panel, as it is held down by a wide lip at the front and is tight against the back panel. Looks like I might have to remove the circular fan element on the back panel to get the base panel out in any case, even when I have found out how to push/pull it up. Am I missing some obvious tricks? Any suggestions greatly appreciated.March 16, 2008 at 6:07 pm #246050Penguin45
ParticipantRe: Help replacing bottom element in Kenwood CK480
Can’t help you with how to get it out I’m afraid, but the element you require is p/no 062066004 – spares@ukwhitegoods.co.uk will get you one promptly.
March 17, 2008 at 4:38 pm #246051wsts
ParticipantGently bending and twisting it till you get it out I am afraid….. stupid design.
March 18, 2008 at 7:47 pm #246052Kirk
Metal plate underneath has to be gently leavered down, as long as the 2 screws on the back either side of element have been removed, it is a stupid design.
Kirk
March 20, 2008 at 11:14 pm #246053Rob_Spalton
Thanks for your replies/suggestions. You can imagine my delight at hearing your opinions on the merits of the design, but I’ll give it another shot now I know I’m not missing something obvious.
December 10, 2020 at 4:06 pm #246054JenS
ParticipantDid you get there in the end? I’ve got the screws oyt but having to use more force than I’d like to try and bend the plate out….any hints and tips gladly accepted!
December 10, 2020 at 9:49 pm #246055electrofix
Moderatorfrom the posts above look like a pig of a job
you may not get a reply as the thread is dated 2008
