Hi folks,
Wondering if anyone can help me changing the door seal on my aging WD41.
The bit I’m stuck at is how to remove/disassemble the plastic “lock” on the outside of the door frame which seems to lock the (jubilee?) clip in place.
Do I need a special tool…? 🙁
I decided to post before using the universal tool – brute force… 😉
Also, (several months ago) the same machine has refused to produce any heat whilst drying – this isn’t so much a problem now as we use a separate dryer but is still niggling me. Anyone tell me what’s the first thing I should check…?
Many thanks,
Andy.
