Help required – Fagor Elegance Washing Machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Help required – Fagor Elegance Washing Machine
  • #20526
    BlueRose
    I have acquired a Fagor Elegance washing machine, model number FU 1358 and have no instruction manual and there is no numbers for cycles on the machine!!
    Does anyone have one of these machines and can you tell me where I can get an instruction manual, or what number to use for a normal 40 degree wash?
    #187360
    Re: Help required – Fagor Elegance Washing Machine
    This one has a separate temperature control, so as long as you select 40c on the dial you won’t discolour anything! Programmes will be split into groups – Cottons, Easy Cares and Wool or Delicates. I’d try the second position in the cotton group for a starter…….
    Fagor UK’s web site appears to be inoperative at present, so I can’t check whether you can download a manual or not.
    HTH,
    BlueRose
    Thanks for the reply penguin, but I don’t know what colour is for cottons, etc. There seems to be a dial with some numbers against a yellow background (4, 5, 6) and some against a white background.
    I guess if I just turn the temperature to 40 degrees and set it on 4 or 5 then that won’t shrink anything?
    Thanks!
    #187362
    Dave_Conway
    Fagor should be able to supply a manual:
    Fagor Electrodomésticos S.Coop
    UK REPRESENTATIVE OFFICE
    LEROY HOUSE
    UNIT 3P, 436 ESSEX ROAD
    LONDON N1 3QP
    PHONE
    INFOLINE : 0870 600 1417
    AFTER SALES SERVICE: 0870 609 3252
    Fax: 0207 354 0789
    E-mail:
    infoline: info.uk@fagor.com
    after sales service : service.uk@fagor.com
    #187363
    richaber
    Hi folks, I am just about to inherit one of these machines, not very old at all but doesn’t spin at top speed. Does anyone know if they use a system like Candy which has the split pulley with the centrifugal weights? Thanks
    #187364
    Carbon brush motor with electronic control. Don’t forget that Fagor tend to use the “out-for-on” system with buttons. Also, you normally only get full spin speed on the cottons programmes.
