Help required Hoover T4420
Home Forums Public Support Forums Help And Support Vacuum Cleaner Help Forum Help required Hoover T4420
  • #100339
    Pww1955
    The power switch on the above vac will no longer latch on, you have to keep the switch pressed down continually. Let go and the motor stops.
    I’d like to split the case and replace the switch but I can’t work out how…..
    I have removed the four screws at the front inside where the bag is situated and can partially open the case but can’t open it more that an inch or two. It feels as if there are a screw or two hidden somewhere towards the back of the cleaner, possibly under the switch/cable retract covers.
    Has anybody managed to open one of these cleaners and can point me in the right direction?
    Many thanks
    Paul
    #480224
    they hide screws all over the place on cleaners
    under the pedals is common
    behind the wheels
    basically look everywhere
    Pww1955
    Hi Dave,
    Have looked all over the machine, even under the label but can’t see any more holes for screws.
    I assume the wheels just pull off as they appear to be all one piece, no removable caps to be seen.
    If you have seen one of these cleaners any idea how you remove the pedal covers or shall I just try and pry them off. I can’t really make things much worse I feel.
    Cheers
    Paul
    #480226
    not seen one i can remember and there is no workshop manual so can only guess. this is a parts breakdown so can get part numbers but finding screws thats trial and error
    the foot pedals are likely and there will be plastic clips holding them in
    Pww1955
    Thanks Dave,
    nothing ventured, nothing gained….I’ll let you know how I get on.
    Cheers
    Paul
    #480228
    Pww1955
    Well, I broke a retaining pin off each cover but as expected the screws were under there. A hidden latch on each cover needs to be pressed in to allow removal by pushing each cover toward the rear of the cleaner. Once opened the switch is a simple replacement. The covers will probably go back on and still function and as it is a second cleaner aesthetics are not important.
    Cheers again
    Paul
    ps…couldn’t give me a part no. for the switch could you, please?
    #480229
    Pww1955
    That’s why I wouldn’t go near hoover spares. Got one for £8 delivered and I thought that was on the expensive side. Anderson Electrical
    Paul
    #480231
    Pww1955
    Dave,
    Cheers for all your help with this issue, much appreciated.
    Merry Xmas
    Paul
    #480232
    no problem m8
