HELP servis M911 3 level pressure switch Pt No.
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts HELP servis M911 3 level pressure switch Pt No.
  • #14085
    TELL
    Hi im back again about this pressure switch, the model is a servis for definite,mod M911 no other numbers or letter etc, have checked again. it just has GEM1100 on panel. and this is a 3 level switch not a 2 as put in before. it has 9 contacts 11-12-13 21-22-23 and 31-32-33. it does not have the multi block fixing down the centre, normal push on tags around the switch itself.
    can anybody give the part no:STUCK NOW.
    ta TELL..
    PS. the numbers on the switch do not tally with the one conn-dist site, (multi block fittings). the numbers are 4-9219 40011700 P3-367A
    95/50 115/65 135/95 340+65620+
    hope this helps..
    #158033
    Washman
    Re: HELP servis M911 3 level pressure switch Pt No.
    Hi TELL
    Pressure switch part number is 520002100 it fits a whole range of Servis machines
    Mike
    #158034
    TELL
    ta mike got the details, thanks
    TELL.
