help smeg dwf 409 ss stopped working!
Home Forums Public Support Forums Help And Support Dishwasher Help Forum help smeg dwf 409 ss stopped working!
  • #36743
    emg321
    hi
    can anyone help? my dishwasher jsut stopped working yesterday,
    i’ve tried everything, it just stopped mid cyle with water in base, think my sink drain was blocked, I’ve cleared that and managed to drain the wter out the base of the disher by draining into a washing up bowl and pressing each programe button in turn which then pumped a little bit of water each time.
    but now it wont do anything, i press the program button and it just beeps then clunks and stops as if it is locked and cant do anything!
    is there a way I can reset it I’ve tried everything else!!!!
    it is a smeg DWF 409 SS and is 4 years old?
    many thanks
    #252158
    Re: help smeg dwf 409 ss stopped working!
    Any flashing lights?
    emg321
    hi it ramdomly changes, first i thought it was an error code 1
    but now now sure
    some times all the lights are on, sometimes the last 3 on the right hand side.
    if I switch it on then off then try to start a program it beeps as if the programe is going to start then makes all the starting sounds then just stops dead within a few seconds?
    Any ideas? 😀
    #252160
    A read of THIS may help………
    emg321
    hi thank you for that, I guess the simple answer is scrap it! oh well i’ll be washing up by hand for a long time to come 🙁
    thank you for your help
