Re: help – smeg wd16ba – washer/dryer
Thanks for your reply. Ive looked through the advice/instructions you forwarded and seem to be doing everything correctly. The machine does activate the drying program selected and tumble the minimal load within however on completion the load is still wet and cold indicating that no warm/hot air has circulated. |During the cycle i can hear air being circulated which must be cold so do you have any ideas why this may be so ?
I noted from the notes that in the trouble shooting questions specific to laundry not drying it mentions ensuring that the water tap is open. Could this be my problem and if so where is it and is it easy to do ?
Thanks for your time
Shaun
