Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › help washing machine being weird
- This topic has 14 replies, 3 voices, and was last updated 18 years, 6 months ago by
markrachuk.
October 14, 2007 at 6:20 pm #31360
markrachuk
Participanti have a zanussi fjs1225w , it goes on i select programme then it starts, you know at the beginning of the prog the water whooshes in well , it does that the whole time, it doesnt stop, the circle does about fifteen minutes then the timer returns to the start again, but the whole time the machine is filling up, the only way to empty it is to pause and select empty , it empties but is still whooshing, the tub has still got abit of water in it, but the door opens. i have tried unplugging it to see if it was just playing sillies , but still the same. please help ,
do i need to bin it and get a new one help 😡 😳October 14, 2007 at 6:33 pm #230893gegsy
ParticipantRe: help washing machine being weird
When you say you unplugged it and its the same, do you mean water still comes in or is it when you power it back up after?. If its the first then I would suspect the fill valve has jammed in the open position and will be in need of replacement.
October 14, 2007 at 6:36 pm #230894markrachuk
sorry no i unplugged it then run the program again, when i powered it back on , it doesnt do it until programme is selected
October 14, 2007 at 6:53 pm #230895markrachuk
gegsy do you still think it could be the fill valve if so how easy to do?
October 14, 2007 at 7:04 pm #230896gegsy
It doesn’t sound like it TBH. More like a pressure system or module fault. There are some on here more familiar with this machine Im sure 😉
October 14, 2007 at 7:33 pm #230897markrachuk
well thanks anyway for your replys
October 15, 2007 at 7:39 am #230898markrachuk
please anyone help still none the wiser.
October 15, 2007 at 8:31 am #230899Simon46
When wash is selected does the drum turn slowly or does it turn fast like spin speed creating the whooshing sound?
Regards
SimonOctober 15, 2007 at 3:56 pm #230900markrachuk
it does get to a spin , but does do its normal wash spin, the whooshing is from the water cos when you open the powder tray it is louder. the programme roughly gets 15 mins in then returns to original count down eg 55 mins then counts down to say 40 , then changes back to 55 again with the consent water whooshing thro the powder tray.
October 16, 2007 at 7:40 pm #230901markrachuk
water is now smelly a bit
October 17, 2007 at 5:29 pm #230902markrachuk
btt please
October 17, 2007 at 5:41 pm #230903Simon46
Does the water drain into a stand pipe or does it connect to a spigot under the sink? If the drain hose is too low the machines water will run out as it is filling(syphoning). Therefore never getting through cycle. Just athought.
S.
October 17, 2007 at 7:24 pm #230904markrachuk
its thro a pipe , but it has work for over a year this way, and it fills up and empties sort of, only when programme is paused and drain is selcted, but all this time the water is still filling it up slowly .
October 18, 2007 at 8:55 am #230905Simon46
Just saying then if the pipe is shoved too far down standpipe into u bend then syphoning may occur. Raising the pipe pointing into say the sink temporarily to test will prove this.
Regards
SimonOctober 18, 2007 at 1:31 pm #230906markrachuk
ok thankyou simon, will give it ago .
