Help WD14 PCB board
Home Forums Public Support Forums Spare Parts Help Help WD14 PCB board
  • #64339
    garnett19
    Hi.
    I need a fully functioning replacement PCB board part number 21500774800 that is already preconfigured for an Indesit washer dryer model number WD 14
    Can any one help ❓
    #356780
    Re: Help WD14 PCB board
    The correct part number is C00143471.
    AFAIK they do not come configured, although that is an earlier type almost all Merloni PCB’s now need configuring with a smart card and a smart card reader.
    You ‘may’ be able to buy one fully configured direct from the Indesit Company.
    #356781
    garnett19
    Thanks for the info, I was hoping I could pick up a second hand board that I could fit without the need to be reconfigured assuming the eeprom chip has the same info.
    Regards Steve
    #356782
    The sad thing is that the PCB’s on Indesit machines are the weakest part of the machine, most of these are scrapped because the electronics have given out in the first place. :rolls:
