HELP!! Whirlpool 6th Sense WM
Home Forums Public Support Forums Help And Support Washing Machine Help Forum HELP!! Whirlpool 6th Sense WM
  • #25761
    Solitude
    Having a problem with my washing machine. I am getting the error “F09” on the display. The washing machine has recently had a pump change since receiving an “FP” error so as you can probably tell we are getting quite annoyed. Wondering if anyone can tell me what the error means and how to fix it?
    Sol 👿 👿
    #207504
    gegsy
    Re: HELP!! Whirlpool 6th Sense WM
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=12318
    Solitude
    my apologies! thought i had typed that in.
    Model number is AWM 8123/S
    Thanks and sorry again!
    #207506
    gegsy
    You have probably got a blockage in the pressure chamber at the front of the tank. You will need to remove front to gain access. If that is ok and then I would be looking at a faulty pressostat or PCB module.
    Un-plug appliance if you are to investigate :plug:
    Solitude
    Thanks for quick response!
    Bearing in mind i know nothing abot washing machines is it better to get someone to do this for us and any idea on how much this would cost?
    Sol
    #207508
    gegsy
    I would then consider using an engineer from the link below given your honesty regarding your ability. Safety first as always 😀
